- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
- Thread starter
- #21
To save you a moment on drawing up the diagram, I would take my power from the power post of the fuse block, put an inline fuse of probably 10A or smaller and have that connect directly to the flasher. Did I get this right?
FYI I was looking for the flasher today and the PO installed an aftermarket flasher which has three terminals (just like the yota version) but he had only the ground connected and one power connection going in and nothing on the third terminal. The flasher itself is wrapped in electrical tapeand is some brand X.
sounds like you got it. If you want to take it a step farther and have cleaner power going to the signals, take the out of the relay and splice directly into the hazard (need to cut the existing into the hazard) I would need to look at mine to tell you the wire that needs to be rerouted.
