- Thread starter
- #41
What is the advantage/difference of snatch versus pull? I see here lots of discussion of using elastic snatch straps, non-elastic tow straps and chain. If somebody is stuck and the tow vehicle is parked to hook up and pull, what is the difference what material to use? If a tow truck came along it would use a cable attached to the winch, which is a non-elastic direct pull. Why would I need an elastic device?
different idea.
Tow strap, you're using the engine to pull.
Snatch strap, you're using the Kinetic Energy of the pulling truck and maybe engine too if you keep it gunned (probably not a good idea in some cases).
K.E. of 6000 lbs at 10 or 20 mph is a lot of energy...
