Does anyone know where to get 1.25"-1.5" wheel spacers for the full float rear end on an FZJ80? Every wheel spacer I've looked at is either hubcentric with a 100mm center bore, regardless of advertised dimensions, or is 1" thick or less. I'm returning a second set already for this reason, they all seem to have 2 center bores and a taper, one bore is 106mm the other is 100mm, the full float hubs measure 106mm. My lugs stick out 1.25" and realistically I need to gain about 2" in width, so I'd like to keep the spacers to 1.25" or 1.5" as a maximum thickness.
