2019 LC200
Upon research, I just found out about SCRUB RADIUS in relation to wheel offset, which I don't quite understand.
Will adding wheel spacer affect this? and will it be noticeable on the road?
My current wheel set up is 22x10 +25 OFFSET
Tires are 285/45r22
the stance is flush on the fenders
I would want to have wider stance for better look.
Plan:
1. Change to bigger Ridge Grapplers 305/45r22 (which is almost a 32.8'' tire) or another option is 33x12.5r22
2. Would also plan to add 30 or 40mm Wheel Spacer to push the wheels outward and have wider stance
3. Cut/adjusting the inner wheel fender liner so that there will be no rubbing
Thanks
Tires are 285/45r22
Plan:
Thanks
