https://www.tirerack.com/wheels/Whe...s&autoModel=LX+570&autoYear=2014&autoModClar=
I'm about to order above Alpha Command 18x9 wheel w/ +25mm offset.
The price is good and I don't want any rubbing especially the UCA.
Did some research but I'm getting conflict advice...
Will it rub or any modification needed to fit with 285/65 or 285/70 Toyo Open Country AT (or the biggest tire I could fit)?
Don't want to use the spacer or BCM.
I like the wheel slightly pushing out of the fender for a more aggressive look.
Also, is the 18" wheel ok for moderate to semi-difficult offroad use or should I stick with 17" wheel?
Thanks in advance!
I want a similar look of this setup... not sure it's 17" or 18"
Thanks in advance!
