I have had a woobly steering on my LC for a while now and it seemed to be getting worse, veering on undulations in the road, I have just checked my wheel bearing and have noticed that the outer bearing (right hand side)has rubbed into the metal washer and worn a groove into it, thats why the bearing has to much play now, is this a common fault? and what might be the cause for this wear, I don't have a replacement washer and it takes two days to order these parts in the UK so will have to clean it up and put it back for now, its as if the inner of the bearing is rotating and causing the wear on the washer, hope you can help guys....regards Mick.
