i have been thinking about getting a supercharger for more power and grunt but i dont even no a price range is for one or if it would even be worth it anyone got an idear or better suggestions to give me more power on the cheaper side? CHEERS!
Some like them some don't.Those of us in the desert have found that cooling becomes a big issue on supercharged rigs due to the fan modifications.
I supercharged mine and have NO cooling issues. Even with big 10 inch LightForce lights blocking airflow. The SuperCharger does makes a noticeable difference though.
could u please share more info about this? I was planning to SC my expedition rig for desert trips but u confirm me that cooling can be a considerable issue. Which kind of temp do u have in arizona?
However if I have to rebuild my 1FZ and then install a supercharger for same money I'll probably go for a GM swap (LY6 and 6L80E) or tundra 5.7 but this is hard to find here and they have lots of tranny's problems. I'm not very convinced about a turbo for desert trips
thanks guys thats pretty much cleared it up! so when i get sum cash together im getting one....... ha if the handbreak lets me!!!!
Summer temps in the lower deserts are rarely below 100 and often exceed 110. Pavement temps can exceed 150.Even unmodified 80s struggle to keep the AC running properly at idle on the hottest days.
As noted before, my brother's done considerable research and experimentation on fan clutches. Mine is running 20k fluid which makes a huge difference.Even with the mods, the SC rigs run hotter. Personally, I wouldn't run a SC in this climate.
I'm pretty happy with the 80 the way it was designed.
I have had a SC 80 now I have a 80 without and if I want more power it will be a V8 not a SC. A SC is more then one without but not up to V8 power.
It sounds like the superchargers that are commonly fitted to these engines develop pretty low boost. Has anyone ever toyed with using smaller supercharger pulleys to drive the SC faster to produce more boost? If done well, this could make the I6 keep right up with the V8's.
