For me, it's not so much the desire for tall and skinny but rather fitment. 35" diameter is already a stretch for the IFS 100. Wide 35's just make it more difficult. I'm sold on the size for the 100 and my next set will likely be the same size. If I did change size, I might do the 285/70R18 (34") for better towing.
All the disadvantages of 18's have been talked about plenty. In addition to Spresso's list, there are a few other advantages I can think of.
-better steering response
-better steering response in case of a total tire blowout
-should balance better vs a 35" tire on 16's. (rubber vs alloy)
Compared to 315/75R16, the total weight (tire and rim) is about the same but the weight balance changes. the 285/75R18 will have less weight on the outer circumference and more weight towards the center, the alloy wheel portion. This will make a slight advantage in acceleration, braking and brake pad wear.
I think the sidewall height of the 285/75R18 is adequate for our 100. It's not really a hardcore off-road vehicle. If going 33's, I'd likely choose 16" wheels. Also, if they ever make a 285/85R16 (35x11.25R16), I'd very much like to try it.
Spresso, regarding the "dust" shield. I took the dust shields off my NSX and the brakes seem to cool better on the track but my NSX never sees rain nor even puddles. Heck, I don' even have windshield wipers on the thing. But for the LC, the argument is that the dust shields make the vehicle more safe becasue they prevent water from splashing onto rotors and thus temporarily reducing braking performance.
I don't live close to the snow but I've read removing the brake dust shield means more salt on the rotor and thus more salt on the caliper pistons making the pistons more susceptible to seizing. But I realize your rotors are larger than stock and there really is no bolt on replacement.
Another interesting point regarding rotor cooling, I once talked to an engineer of a custom wheel company. He said in their testing, it didn't matter whether the wheel had a solid face or had spokes, unless the wheel was designed like a fan, the spoked wheel acted like it was solid when turning. He said, in fact, the solid wheel (not spoke design) was better in that it had better heat transfer and that played a role in brake cooling.
And come to think of it, when I'm hard on my brakes, my alloy wheels are super hot. And this makes for an argument for alloy wheels vs steel wheels as alloy wheels have better heat transfer.
Now, I don't know if there is any truth to all that but it's something to think about. I'm surprised they don't have water cooled calipers and rotors. Okay, enough rambling.
