glad i found this post... i have been wondering about this for awhile. seems like easiest way to swap my 83 fj60 would be a 62 third?
not sure if i read this right...![]()
yep..
Guys,
Quick questions:
I am getting ready to swap my Thirds for a pair out of a 62.
1- do I need flange adapters to mate them with my 83 BJ-60 drive shafts?
2- what should I replace/service in the front end while I have the axels out on the front end? (I have new seals for the rear already).
Assuming your thirds follow the same vintages of US parts, then yes. You won't need adapters however, you can simply swap the flanges from your current thirds onto the 62 units.
As for parts, I would really recommend a knuckle rebuild at the same time and inspect, replace or repack the wheel bearings.
If you decide you just want to replace the flanges with new ones or end up needing a knuckle kit or parts, give us a call![]()
Not to beat a dead horse, but swapping flanges on a crush sleeve is not the best idea for longevity IMHO.
So Kurt,
Do you make solid spacers with your adapter sets?
I have never taken apart the thirds before so I don't have hands on experience here- but the common wisdom seems to agree that using a solid spacer and shims is a better way to go when replacing a crush sleeve.
Or I might I just go with the adapter and avoid opening up a perfectly good 3rd member?
Which I am sort of avoiding for lack of experience and tools ;@
-ryan
Kurt,
I just glanced at the U-joints and don't have any idea how to get them apart. Any hints? I would like to go this route if possible- remove flange from 3rd members and swap.
-thanks!
Ryan
