What Spark Plugs? (1 Viewer)
I have used every plug on the planet; the best I have
found are the either the original or Split-Fire(really)
If you have an old worn out electrical ignition system,
and do not plan on replacing everything, I would suggest
IRIDIUM plugs by Denso; they need less energy to
make a good spark, so work well in older systems.
I use them and they are great; only thing they are expensive,
around $10-12 US each, but will outlast the truck.
G
Hi Grey, based on your recommendation I´m diving-in on the Denso Iridium, for my 1984 FJ62 3F engine (factory original). The thing is that you just can´t trust suppliers here, and using web resources to find ther right model number for sparkplug has been for me difficult.
I´m counting on your wisdom to sort this out; I read before that Platinum is out for my dear “Burra” which is how we lovingly call our Land Cruisers FJ60’s. Thanks
You are replying to a post from 12 years ago
Why is it so hard to find spark plug numbers? A cursory search on google gives you dozens of 3F plug part numbers. Before you put a new plug in , you should always compare the old with the new for the protrusion length.
I doubt Iridium plugs will make much difference on a slow revving old 3F
I used NGK 1028, they were just fine
