Sooo.... My fuel filter was clogged with debris from the gas tank and stalling out the truck. I cleaned out the fuel tank and fuel lines and replaced the fuel filter. (Somewhere in between here the horn, hazard lights, and headlights shorted out)-Headlights work again for no reason whatsoever, but horn and hazards are dead.
Anyway, I start my truck (78 FJ40, 2F) and it runs strong choked but if I push the choke in it sputters and dies. It will drive strongly 1/2 choked but then the motor dies at stoplights. Starts right back up on full choke only, then runs at 1/2 (and dies at stops). It will not idle without the choke.
I did just change the coil wire (the last one broke)... but the new one does not feel or look like it fits correctly...
Would the PCV valve have anything to do with this? It feels clogged.
So...-Coil wire, PCV valve, or something else? and what is going on with the wiring? I didn't even touch it...
Thanks for any help you might offer
