- Thread starter
- #21
The route I am going to take is a retrofit. There is no doubt that it is more expensive than just a "plug 'n play" kit but I think that any HID kit without proper projectors is a huge danger to others on the road and would not condone its use. Do some research on the above threads that were mentioned and save up for a good retrofit.
If you don't feel like hacking up your headlights, have someone do it and I promise you it will be worth it. I've also looked into the two little light bars on either side of the license plate, but a retrofit will come first. If you do go the bar route, make sure you mount the switch where it will be easily accessed quickly in case you run into oncoming traffic, those things can be brutal and cause accidents very easily.
Just my .02
A retrofit would definitely come at some point! Where in MA are you? I am on the south shore, if you get yours done I may ask you to help me out with mine!
