Water/Air Intercooler had the biggest impact on my truck. Second would be Evans Waterless Coolant.
What impact did the Evans Waterless Coolant provide.
2LTE's have a tendancy to overheat and crack heads. I tow a 3500lb camper (loaded) with my Prado. The Evans Waterless does not boil until 375F. Basically it means I can push that little motor as hard as I want and the coolant does not have any localized boiling issues in the head like a normal coolant does (localized boiling causes hot spots in the head which is what leads to cracking - with all IDI turbo diesels, not only the 2LTE). I have run up to 240F with no issues what so ever. Been doing this for years now. The stuff has proven it's self to me. Great peace of mind. Engine would be long dead with regular water coolant. Added benefit, no water, no corrosion. And it lasts for many years.
Did you flush it per Evans' product to rid system of water?
HaHa! If you knew Nick, you wouldn't have asked!!
@tommybj73
This is probably a stupid question, but I'm gunna ask. Its about your compressor.
Can you still use your aircon as an aircon in your car? it can only be belt driven to run? you can't just supply power to it?
I know, I just made you squint and say WHAT??
In regards to converting A/C units to compress air, i had that conversion done to my old 61. Worked a charm, however i wanted a compressor not just for tires, but to blow dust and other crud out of the car (in hard to reach locations). I finally noticed one day that there was a constant plume of oil since, as Sadam_hussain pointed out, it is an open system when used as a compressor. This i mention just because i stopped blowing crud out of my car with it as i didn't want a coating of oil on everything. Apart from that, it was excellent.
@tommybj73
