What have you done to your 100 Series this week? (61 Viewers)
Rebound Pro udate.
I was recommended to use vicon o rings. Was told the Chinese Icon rubber doesn't last. $10 for 100. I used dielectric grease on the rings. Rattle can anti-seize with a hole in cardboard helped a ton with how messy the stuff can be. It also kept it off my o rings.
Installed a Pecron car charger to keep my power station top off via the alternator.
It outputs up to 500w, but I have it dialed down to about 400w. Has a smart voltage so it won't deplete your starter battery. And it's plug and play.
Only downside are the loud fans, need to see if I can replace with lower db's
How do you like that charger so far?
Swapped out the stock size highway tires for 275/65/18 (32's); Copper Discovery ATP's
I know, like everybody else I would have preferred 275/70/18 (33's), but I already had 5 of these, they are 4 years old, and have under 10k on them. May as well use them or loose them. So robbed them off the LR3 and put them on the hundy. Between them, the running board delete, and trimming the rear mud flaps, finally losing that mall crawler look.
I'll be going on a trip this weekend, so will see. Testing I can get 500w but I lowered it for now to about 400w. That 4-5 times what you can get via the cigarette lighter connection.
Easy install and at $150 makes it an easy investment.
Only negative is the fan noise, I'll have to see it I can swap out to a quieter fan.
35 10.5 tires fit well. Very happy with end results. My clunk is completely gone thanks to OEM cv's and flanges. I used to grit my teeth shifting into D and R. New rack cured my sloppy steering and Highway wander.
Threw on some ebay corner lights I bought 4 years ago. I should have installed long ago. Faded lens and orange looked dated.
This looks great with the open 5 spoke window. Tow points next?
(your wheels always make me want center caps)
I have the ironman front tow points that’s red, you just gave me an idea :rofl:
but I saw once here, not sure if it’s Jason of TT selling it but it’s aluminum billet soft-shackle friendly tow points -just can’t find it anywhere NOW those are really nice.
My NAPA outer CV clamps was showing little cv grease so while I have access in the IFS I retightened those clamps.
Jason has an option for soft shackle on that page. Not sure if those are the aluminum or not though.
Finally got around to wiring in some new to me seats from a parts LX. Turns out the 04 and up use a different harness so it was fun. Also installed a slee battery tray and picked up some used tundra wheels to refinish this winter. Trying to get this thing ready to go to Cruisers on the Rockies in July.
