What have you done to your 100 Series this week? (30 Viewers)
I've run 1.25's and 2's. Any vibration I've ever had has turned out to be an out of balance tire issue.
Jim
I wish that was the case. I have the same exact vibration I did before I got new tires.
Changed misc evap hoses and ventilation hoses
^ old hoses were cracked and taped with electrical tape, replaced new
^ Only half of the charcoal canister hoses available. The other side was discontinued
^ New PCV and vacuum hose
^ these valve switching hoses came in a set of two, also replaced new
Yes I am planning to buy new power steering pump hoses soon. Those are not looking so well
Wanting to do this as well. 💪
@Land Shark there is also a 5 pack on ebay to include the rear cargo door.
Thanks fellas. I don't have any that are failing at the moment but will probable pick up on put on the shelf JIC. I remember a thread I was reading some time ago and sourcing these was problematic.
did these require any modifications?
I can let you know once I take mine apart because Harry's 2005 may be different from my 2000 and your 2001. I am guessing ours should be the same.
Would love to pop over and help if you don't mind. Yes I just did invite myself over hahah. or hell if you want come over my house I have plenty of tools and cold beer
2” wheel spacers removed. Curious to see if this helps with my 70+ vibration. Def not digging the look so may need to pick up some 1.25” spacers.
I have considered using different thickness of wheel spacers before when I ran them. Like the front is 1/4” thicker than the rear because of how IFS behaves and the front wheels getting tucked inward the higher the lift is. So that the front wheels has the same width as the rear wheels.
I threw in my 100’s first timing belt, water pump etc and gave it a full service and clean this week. Looked pretty decent in there. The hyd tensioner was just starting to seep a little but all in all not to bad.
Installed Depo headlights with d2s projectors and xb35 ballasts during a break in the snow. Still need to aim them properly, but what a difference.
I was planning to retrofit my oem headlights but ended up finding these at a salvage yard while looking for a spare set. I'll probably still do the retrofit since I already have all of the parts and prefer the glass two piece headlights. These will likely be for sale in a few months if anyone's interested.
Are you getting ready to sell those headlights yet?
Man I wish I had seen that five pack. I had to order a fifth one separately for the hatch which got here today. :-/
I was looking for a while and was not wanting to do that and finally stumbled across the 5 pack! crossing my fingers my motors have the brass collar
Joined the 100 on 35s club today... only had the tires sitting in my garage for all of 6 months before making it happen....
What a week! Finally got my new Headunit installed. Threw up some more info in the stereo FAQ that hopefully someone finds helpful in the future. Amp bypass is a must!
I also spent some time removing all the rust and old foam from my factory skid and then hitting it with some Rustoleum Rust Reformer and then a topcoat of flat black.
Here's before...
..and after, installed
I really need to do a better job of learning to take pictures while I work just so I have more pretty stuff to post.
I also got my new foglight housings in. Super cheap from China, and here's why...
Luckily you dont notice it too much when they're installed, and frankly anything is better than what was on there. Both the previous ones had been flooded out, and one had so much black mold in it that it was just unusable. Dropped some powerful LEDs in there, since I rarely use the fogs (never on the road) and when I do I really want to see.
Lastly I got in my new "JDM Offroad Edition" bumper guard. I just got it up for a test fit yesterday, but it will be awhile before I get time to paint and install it. I know it's not everyone's cup of tea, but I love it!
