@nickolai Without Malice.
Well your first paragraph is actually accurate.
Your second paragraph is accurate as well, machinery needs maintenance, it's a fact of life, a 250 dollar washing machine or 50 million dollar jet fighter.
Your grasping at obvious facts is at best a weak effort to bolster some of your earlier posts.
Lets take your 'fact' about the T26 turbo, of course it will need servicing, it's mechanical, it runs at very high temperatures, it spins at thousands of revolutions per minute (even still spinning when you switch off the engine), no magic here, it's pure common sense, it will need repairing at sometime or maybe never depending how you drive and look after your engine.
Changing oil at 5,000 MILES is recommended, however of course the individual's use of the vehicle should be taken into account, but also the progress in manufacturing oils. A FACT is that modern oils can protect 30 year old high mileage engines, and believe it or not to at least 12,000 miles, there is data to support this. Add this fact to a modern diesel engine and you can see why service intervals are now at least 20,000 miles, if driving more motorway miles then that figure will climb considerably higher.
You keep using the word 'magical', your right, there is nothing magical about a 30 year old truck being immune to needing servicing, I don't recall anyone stating that in the first place anyway, but isn't that true of any vehicle regardless of age?
You mentioned not all of the servicing is DIY, and could be spendy, again I challenge that.
You need to have an open mind. If you are not particularly mechanically minded but have decided an old car (not necessarily an 80) is for you, then you would either have plenty of spare capital to be able to have the vehicle cared by a garage, but if not particularly flush with cash then you will invariably join a club that specialises in whatever marque/model you have set your sights on. One of the facts you are missing, is that older vehicles are easier to repair albeit taking longer. With modern vehicles 3/4 of labour charges are finding out what's wrong with it in the first place. Consider this factual event. A customer calls me because her Skoda Fabia glow plug warning light has come on, this vehicle is around 11 years old. She has already mentioned it to a couple of her neighbours that her vehicle handbook said 'Return to dealer.' One of the neighbours who is an ex mechanic, has the art of sucking through the teeth and waving his head off to a tee, as he tells her that it was going to be expensive for sure.
Car was starting and driving fine, I get her to pop over to the garage I had at the time, I replaced two brake light bulbs, cleared the error with OBD software, job done! You see in Spain, if any one of the three brake lights are not working then no big deal, but lose two and you a driving an illegal vehicle, so one dashboard light used to indicate an issue with something like 40 different problems. Now if that had been say for example a fuel pump issue, I would have removed the pump and sent it away for servicing, it is a specialist job to repair, but the cost would have been the same if not cheaper for the pump on an 80 and why, because the pump on the 30 year old 80 is mechanical, the pump on the 11 year Skoda (VW engine) is electromechanical.
Despite being a mechanic I joined MUD, I had virtually no experience with the 80 but had owned a Land Rover (similar layout but not as tough), but was used here in Spanish competitions, but it is better to be informed than find out later that there may be issues with certain models. Immediately a savvy member warned me of the big end bearing issue the 1HDT engine had!
So I made the purchase and changed the big end bearings. For me I think it was a couple of hours under the engine? If I had not been a mechanic, and not particularly flush with cash then there would undoubtedly be a 'how too' in MUD.
In closing, my point being, scaremongering is just that, it's BS. Do a little research, buy your chosen vehicle and pay the garage to fix it if you have the capital or, join a club such as MUD and learn to DIY.
I cannot explain any clearer than what I have thus far, so have to call it a day.
Regards
Dave
Regards
Dave
