I have an H41 with a first-gear-popping out problem. I know the H41 is known for losing the first gear synchro, so thats my suspicion, but I want to check...
My shifting is still fine, no problems going into #1. However, when barely moving, usually when pulling out of a parking spot, the transmission will slip out of gear. The shifter only moves maybe 1/2" and appears to be still in gear, but its not. I have to pull the shifter back to neutral before I can put it back in gear. Its not violent, by any means, its sorta like :
: not in gear anymore.
Its worse when the rear of the truck is low, as though the weight of the shifter itself is enough to tug it out.
So, classic synchro symptoms?
