OME front coil part number, 2885, 2887.
I spent some time over the weekend to wet sand and clear coat my headlights. I used 2k clear and the finish is very good but I have pretty significant amount of crazing in the lenses. This bought me some time before I have to replace them.
Also replaced the bulbs with Phillips H9 and 9011 bulbs.
Since we are sharing winch solenoids here’s mine I finished a few weeks ago. It’s an Albright solenoid and I also remote mounted the control plug. I wanted to keep the constant hot wire as short as possible so I mounted it on the drivers side.
In the 2nd to last pic you need to add some split loom to cover the wires where the wires go through the the hole under the headlight or they will rub through. I was adding a trans cooler to mine last weekend and looked at my winch wires routed in the same place. The insulation is showing a small divot where it was against that edge. Anywhere where wire touches an edge you want some split loom or other abrasion resistant sheath even if the edge seems really blunt. Its crazy what road vibrations will do over time
