- Joined
- Jan 18, 2007
- Threads
- 37
- Messages
- 598
Some mountain stuff.
I was there, it was a blast.I think it's open to all Toyotas. I wanted to go this weekend but was traveling. I will be going to the next event.
Good to know, I have some that are cracked, but not quite as bad as yours yet.Replaced #8 coil. I've been doing them singularly as they die. This makes number 2 in two years, figured I'd get all the life out of them I can. I carry a spare Denso in the glove box. 285k on the Oem coil pack, a real trooper. View attachment 3662605
Ughhh I hate that I missed it. At least I'm now local to the area. Need to see if there are any other events somewhat close between now and August.I was there, it was a blast.
Check the Windrock site calendar, they have a ton of events and quite a few Toyota based runs. Mardi Krawl is in September this year in N AL at Hawk Pride ORV Park. Never been but might go this year but not sure.Ughhh I hate that I missed it. At least I'm now local to the area. Need to see if there are any other events somewhat close between now and August.
I agree, but haven't added up the cost of all my tools and now my shopI wouldn't be able to off-road if I had to pay someone for all the labor. It's an excellent skill set to have and you lose way less money to depreciation!
Yep.I agree, but haven't added up the cost of all my tools and now my shop. It was honestly a pretty cheap, necessary skill when I was younger and did it solely for the money savings, but really ballooned as I got older, got more $$, and bought more toys/tools
Regardless of the return on investment, it's a ton of fun. And provides the ability to fix your own rig (or someone else's) on the side of the road or the trail.
She had a headache we did not get wet.
Could be, but it’s a brand new OEM rack in the front end. Less than 3k miles on it.I had that happen. It was actually the steering rack bushings letting go. Took me a couple weeks to figure it out as the alignment shop re checked the alignment and it was fine. Installed a reman rack and it's been fine ever since. I rally-drive my GX on gravel and have never had a cam bolt loosen or move.
Tabs are in great shape. First thing I checked.Check the tabs that the cams sit between and see if they have bent or are broken. If the cams were marked previously you may be able to get it close.
I bought this kit.
KPO Off Road Toyota Alignment Cam & Cam Tabs Upgrade, Toyota, Tacoma, 4Runner, Tundra, Sequoia, FJ Cruiser, Lexus GX470, GX460, Free Shipping
KPO Off Road Toyota Alignment Cam & Cam Tabs Upgrade, Toyota, Tacoma, 4Runner, Tundra, Sequoia, FJ Cruiser, Lexus GX470, GX460, Free Shippingwww.1stgenoffroad.com
If you go this route ask me about torque specs. I measured the run on torque for the Stover nuts.
The rack bolts might have backed out. That actually happened after I replaced my rack....causing even more frustration in finding out what was wrong with it. I would check them if you are crawling under there, as well as checking the torque on your cam bolts.Could be, but it’s a brand new OEM rack in the front end. Less than 3k miles on it.
Solid point.The rack bolts might have backed out. That actually happened after I replaced my rack....causing even more frustration in finding out what was wrong with it. I would check them if you are crawling under there, as well as checking the torque on your cam bolts.
