What Did You Do To Your Diesel Today (WDYDTYDT)
New injection pump. I'm told it is for a 1HD-T.
22100-17880. Not sure if this will bolt on a 1HZ. This part number corresponds to a 1HD-T/FT. Any knowledge out there?
1HD-FT pump even if it bolts on i wouldn't try to run it on a 1hz. the injector pressures are way higher on a FT. 1hz pump should be cheaper too
Thanks TB. What about getting new injectors to match? Although this is now getting a little overboard...
New winch day.
I think this may be the first Carbon Winch in the States I've seen. See if it holds up.
need a new complete cyl head, pistons, connection rods, manifolds, injector lines and drill a few holes in the block to get it to match.
Hello,
It would be better to get an engine assembly to match the pump...
No need to fabricate or drill holes. Bolt-on and you are all set up.
Juan
