What could have caused my LX 570 to show "Check PCS System" on dashboard? (1 Viewer)
Wisconsin
So, here's what I tried with my 2014 LX 570. I turned on MTS for rock and climbed a small hill. After that's done, I turned off MTS and then I got this on the dashboard. What could have caused this? Regardless if I moved to 4H, it still shows 4LO and the CHECK PCS SYTEM with the orange triangle plus exclamation in the middle icon on the dashboard. I couldn't figure out why. I turned off the engine and turn back on but nothing changed. I finally turned off the engine, got out of the vehicle, and let it sit for like 10 minutes or so then start the vehicle again and everything looks normal. Any idea why? This is the first time I tried MTS since I purchased the vehicle. I'm afraid to try MTS again if this keeps happening again.
Okay, so what should I turned off or turn on before using MTS? Again, this is my first try and so I'm not sure if I did it right. Should I turned off traction, parking assist, and RCA before using MTS/Crawl?
I had this on mine, the radar sensor was dirty, the second time the parking sensor was having an intermittent fault when wet. It would freak out when I tried to put it into 4x4 and cruise would be inop when it was acting up. Hope this helps
I get that message often when driving in wet snow conditions. The sensor gets covered and can't see anymore.
Is there a way to turn off this PCS system on the 2014 LX 570 when off-roading? If not, it's very useful is it. Are you referring to the sensors in the front bumper?
Pretty sure there is no way to disable it. No the sensor is in the grille behind the big L badge.
So that means if one is off-roading and any dust or dirt covers the sensor this error will show up again then. What about snow? I assumed snow will do the same thing. This is a bad design then if that's the case. I was looking at this YouTube video and it shows there is a button to turn off PCS. However, I'm afraid I don't have that on the 2014 LX 570 model.
When I just disabled my cruise, or disabled my parking sensors it stopped the issue for me. My buttons are all around the steering wheel and I have never had the problem in my wife's LX so I apologize I'm of no help
Yes, a light coating of snow will block the sensor and it will throw that message on the dash. Easy to fix, just wipe it off, restart the truck and it's fine.
Some people b***h about the computers that are taking over some simple driving tasks, but I guarantee you that when it matters, it is much faster to react then you will ever be. I've had mine trigger twice when deer ran out in front of me, and it got the truck safely stopped before I was able to get my foot on the brake. The seatbelt also yanks you back in the seat, it's like the truck is saying "I got this...". I would not disable it even if I could.
Unrelated to the initial issue but if, let's say, I have the adapted cruise control on with the PCS system, will the vehicle come to a full stop if the vehicle ahead stops?
I *think* the adaptive cruise shuts off eventually, like around 20 mph, so no it won't stop the truck if you encounter traffic. But if you don't hit the brakes, then the PCS will wake up and stop it. It's more of a panic stop, not something you'd want to intentionally use.
Wow, good to know. I have a 2018 Subaru Legacy and the adaptive cruise control actually stops the vehicle if the vehicle in front stops for traffic light or for any reason. I wonder if the 2016-2021 LX 570 stops the vehicle or not. Thanks for the clarification.
As data points, my 13 didn't have any way to disable PCS, but my 16 has a switch to disable it. I spent a long time on the phone with Toyota trying to figure out if there was some way to disable PCS on the 13, but no dice.
I am dealing with this problem also. The PCS always used to work well, with pre-tightening the seatbelts, and emergency stopping when on cruise control. This winter, or spring, I just started getting a constant PCS warning every time I turn on the car. The warning also beeps intermittently, not at a regular interval. Sometimes it is quite annoying, it is also annoying all the time.
I have tried cleaning the sensor, I have tried disconnecting the sensor, but that does not seem to be the issue. I am guessing it is probably the PCS unit itself, which sounds like an expensive P. I. T. A. to fix. As needs recalibrated by Lexus or Toyota after you change it.
Anybody dealt with something like this? I also tried disconnecting the battery and leaving it off overnight, but that didn’t solve anything.
I also tried the radar, cruise beam axis adjustment protocol with steering wheel shortcuts. This also did not have any long-term effect.
Yes, the 16+ has full speed adaptive cruise meaning it will come to a complete stop when necessary. When traffic starts to move again, you either tap the cruise control stalk or the accelerator pedal to get moving again and match the speed of the car you're following.
It's sometimes nice in stop and go traffic except in Utah where leaving a safe distance between yourself and the car in front is an invitation for the small pp guy in the riced out pickup to cut into that space and brake check you.
Any luck with fixing this? My 2008 LX has the same issue and same message aswell, if you have the Tech stream software perhaps use it for re-calibration? also my seats belts still tighten when sudden braking.
