I always felt like I had way too much weight way out back on my 100 - bumper @200-250 lbs? + 100 lb spare + 2 jerry cans @80 lbs - almost 400 lbs plus cargo. I'm no engineer but I believe it acted like a lever and under certain conditions it produced some bad bouncing and even loss of traction off road when climbing up loose rocky trails.
forum.ih8mud.com
Good question. I just like going fast(ish) offroad - I wasn't planning going full send with a LT kit initially. But I was going to with extended coilovers and rear shock relocation. 2.5s with resis up front and 12-14" in the rear. Maybe one of those +2 expedition kits and glass eventually but I wanted to try mid travel first.When you talk about how you like to use the taco, are you talking about mid-travel (longer coilovers) and ruts, are you talking a +2 kit and hitting whoops at speed, or wash outs at 25? And is that the primary goal?
Edit: I ask because use will dictate inherent failure points to a large extent.
That is what I build mine for.Good question. I just like going fast(ish) offroad - I wasn't planning going full send with a LT kit initially. But I was going to with extended coilovers and rear shock relocation. 2.5s with resis up front and 12-14" in the rear. Maybe one of those +2 expedition kits and glass eventually but I wanted to try mid travel first.
Primary goal is (was) hitting desert trails at good speeds - 30-40mph. Nothing crazy. Just thought it would be fun to do that in a supercharged 6 speed Tacoma. I had a slinky setup on my 100 and loved airing down and blasting down trails.
Where I started to go down the failure point rabbit hole with Tacomas was exactly that - what do I want to do now vs what do I want to be able to do in the future?
- Immediate: I added bed stiffeners because people were seeing cracks and damage even with moderate use
- Immediate: Hesitated to add weight up front because people report radiator brace cracks under light offroad use. This one is especially annoying because there is no prevention besides not offroading.
- Long term: People report bent LCA mounts and are unable to align their truck after bottoming out
- Long term: People report bent spindles after jumps, big hits, etc.
- Long term: Not sure how durable a lightweight, non boxed frame is. Some guys box the entire frame when going LT.
All that brought me back to a 200. Why put all that time and effort into a light duty truck with a minivan engine that won't even make stock LC power after a supercharger...
Having said that I think I can still get a lot of that type of enjoyment out of a 200 with a good suspension setup. Might not be as fast and light but the durability would be worth it to me.
Love it! Exactly what I'm thinking. Do you use spacers in the rear to match the track width of the front? Love the look without a roofrack as well.That is what I build mine for.
Look into the Tundra front end swap.
You will probably want 3.0 shocks as these are pretty heavy. If you are going fast in rough terrain, 2.5" ones will over heat.
Duro bumpstops or simailar. I ended up custom mounting King bumps
17" wheels for more sidewall
Strong front skid
Some sort of roost shield for rear shocks.
Thanks guys, I miss it! Thought about getting a 105 now that they're legal but I'm leaning 200.
Maybe. My wife LOVES our '21, so much that I really can't modify it unless I find her a car she likes more - which is impossible. Maybe an LX600 but she doesn't like how those look. You know how it goes.A second 200?
Yes, spacers in the rear. Forget if they are 1.25" or 1.5", but no issues. I was about do weld on spindle gussets, but found out Monica has had no issues with the stock spindles. So the gussets are on the shelf.Love it! Exactly what I'm thinking. Do you use spacers in the rear to match the track width of the front? Love the look without a roofrack as well.
I frankly don't get why people want to blast offroad at 60 miles per hour in the open desert. Never mind possible damage to your vehicle or to the environment; think of all the things you'd miss seeing up close:
Gila monsters. Scorpions. Snakes of all varieties and temperaments. Massage parlors.
Think it's fun in an LC?It's a hoot to blast through washes and the open desert. I think it also has practical utility as a suspension that handles that kind of work means it'll take washboards with more stability, comfort, and durability to the rest of the rig that won't be trying to rattle apart. There's some really long tracks in open expanses out here and it's useful and fun to run at almost freeway speeds.
Sounds like you might be considering dipping a toe into long travel. If so I think you’ll find the weak points in the LC are platform issues (wheelbase, rear seat, weight) when compared to the Tacoma. A taco with DMZ SUA and a bed cage will have a rear end ride through the rough stuff you will really not get on the LC.
I think a lot of those issues can be fixed (JDFabs lower mount, spindle gussets, frame boxing) but you’re working with a platform that will be a lot easier in the long run to have some real fun at speed.
All this…why not just get a Ford Raptor or Dodge TRX and call it a day?!
Why waste time and $$$$ on a platform that is not meant for such duties from factory?
That’s wild!!Yes, spacers in the rear. Forget if they are 1.25" or 1.5", but no issues. I was about do weld on spindle gussets, but found out Monica has had no issues with the stock spindles. So the gussets are on the shelf.
Perhaps a tundra then? Several wheelbases to choose from, the 5.7l, and an endless vat of aftermarket parts.
Still would have to deal with the frame?
I need to updated it but I started a thread with the common replacement items we see on Monica after 1000 miles of racing and subsequently we start seeing on heavily wheeled 200’s after ~100k. In fact many of our top selling 200/570 service kits are those inspired by the replacements Monica needed post-race and we started seeing on customer vehicles. A perfect example would be the front unit hub assemblies. The 100/470 with servicable (and thus greasable and adjustable) wins in that realm. But, we offer a handful of different wheel hub options for the 200/570 and a spare is easiest enough to pack along, particularly if you roll with other 200’s/Tundras/Sequoi’s regularly. The starter on the 200/570 often gives zero warning when it peace’s out, at least the 100/470 click for a year or two
EDIT: the search function seems to be down, I’ll try and find the thread later.
That's awesome, I would love to see that!
forum.ih8mud.com
I still need to go through the Monica thread - but have you reinforced anything? Or is it basically a stock setup?
I would love to, I appreciate the invite! I'll message you. Also I blame Adam for all this, one trip trying to keep up with him and now I just want to go fast. hahaSearch is back up. Here is that thread: I could add another dozen items that we are commonly seeing as of late.
The things that fail and how they changed 100 vs. 200
I was always impressed by the size and girth :D of many 100 Series parts compared to their earlier counterparts. Of course weight also increased along with horsepower/torque so it was a given that things needed to improve. Minor stuff like 29 spline flanges, 32 spline shafts, massive CV's and...forum.ih8mud.com
You need to come check it out in person next time we have it here at Cruiser Outfitters or up at Canguro HQ (Farmington) when doing race-prep. Uppers, lowers front and rear are stock. Stock mounting at frame side. Stock knuckles/spindles. Stock brake parts. Verify little reinforcement is allowed in class when it comes to suspension. We do have much larger front shocks with reinforced and remote shock mounting both front and rear. Class rules allow this.
