Water dump
Darlington, SC
Recently changed out my heater control valve in my '95. Ran it up to temp and antifreeze/water began dumping from high up on the engine drivers side. Today i removed front wheel to check if my heater hose had come loose, it had not. While out there i decided to bypass the rear heater. Started the truck ran it up to temp and same thing. I can not tell exactly where it is coming from. Any help on what to pull or to check? Am i looking at a cracked head?
PHH or throttle coolant hose
Would be my guess as well. Both are right next to one another tucked up under the lower intake manifold not far from the firewall (both come off of the head).
