'Development Potential'?I wonder why Toyota insisted on an iron block for the 2UZ, but then have it weaker conrods. Iron blocks might technically be stronger, but only if you’re making crazy power.
Hm yea I suppose the Japanese bubble economy was coming to an end when the 100 series was being developed.Iron blocks are cheaper to manufacture. Way cheaper.
I figure the 2UZ development went about like this: Mgmt gave some engineers the great 1UZ, then said, "get me more torque, make it cost 2/3 as much, and make it just as reliable." They left for some sake bombs and came back to the 2UZ plans.
Cast iron blocks are way stiffer than aluminum which helps them last longer. Also the newer UR engines are having headgasket issues some are attributing to the aluminum block since it heat cycles faster than iron.
What you say about aluminum is true however with good normal maintenance those 3UV have been known to run forever as well.
I believe there have been few 1 million mile 3UV engine's as well.
Lol errrr 3UR-FE 5.7l v8 Tundra and LC engine. Thanks for the catch.
AFAIK the 1/3UZ never bad head gasket issues though. Maybe it’s more likely to happen when you have an Al block engine in a heavier truck?Cast iron blocks are way stiffer than aluminum which helps them last longer. Also the newer UR engines are having headgasket issues some are attributing to the aluminum block since it heat cycles faster than iron.
I’ve never heard of this either. Would love to know more.AFAIK the 1/3UZ never bad head gasket issues though. Maybe it’s more likely to happen when you have an Al block engine in a heavier truck?
Same with 3UR enginesI’m revisiting their thread since I continue to notice how 4.7s will have remarkably few leaks, even up to 500k miles, while a 1FZ over 200k will be coated in oil and in need of a reseal or even rebuild. Does anyone know what Toyota changed in the 2UZ to prevent the famous leaks seen in the earlier straight six motors?
I also see this to a lesser extent in the 5VZ vs 3RZ in the early Tacomas and 4Runners. Toyotas V engines just seem to retain their oil better. Am I into something or is it just happenstance..
Hm yea I’m still wondering what was different about the old inline-6 engines that may have predisposed them to more common leak areas and greater oil loss. I don’t hear about the valve stem seals or oil pan being such an issue on the V8s for example.UZ, VZ, and RZ are tight, but they aren't perfect. Rubber is still rubber, and it will take a set and leak. Each has a couple notorious leak points. Valve covers are common with age. They all eat rear mains with similar failure rates.
Their main reasons for being "tight" are the minimal opportunities for oil to get out, and most of those seals are in joints that work well. And Toyota's FIPG is some wickedly good stuff to boot. Toyota and Merc have some next level sealant chemistry going on.
But if not mistaken, in the '98 hundy before any of the others and the reason it was put in the others.The 2UZFE was used in the Tundra, Sequoia, 100 series, and 4th gen T4R.
That speaks well for it.But if not mistaken, in the '98 hundy before any of the others and the reason it was put in the others.
