SmokingRocks
hopelessly addicted to Cruisers
So everyone knows that it's a good idea to regularly exercise your winch by winding it out 30' and spooling it back in every couple of months. This is meant to get it hot enough to evaporate any water in the gear set.
Buuut what most people never do is a full-on service every couple of years. I've found a good write-up HERE and a good video HERE detailing the process, however, the winches they feature are not a ZEON and despite being an excellent googleboxer I've not been able to find any information regarding how to tear down the ZEON. So I'm going to be the Guinea pig and do it for you all.
A full winch service accomplishes the following:
- Inspecting / cleaning the motor communicators
- Inspecting the motors bearings
- Degreasing the planetary gear set handling any corrosion then repacking with new grease
- Inspect and cleaning of all contactors
- 13mm Socket
- T30 Torx socket
- T25 Torx Socket or impact head
- T45 Torx Socket
- Solid Work Bench
- Parts Cleaner
- 400 Grit dry/wet sandpaper
- Pick
- Electrical parts cleaner spray
- Bearing grease of your choosing
- Exploded Parts Diagram for the Warn Zeon 12 **Attached to this post**
