- Thread starter
- #21
Planetary Gear Set Reassembly (cont)
Replace the intermediate ring gear seat clip
Place the composite spacer in
IMPORTANT NOTE:
Now the final gear set can be installed, this is where I made a goof. As you see in the first photo below the inner circle opening of the outer most face of the planetary gear set is smooth, this is the INCORRECT ORIENTATION. The side that has splines on it needs to be facing out. If you make this mistake like I did you'll figure it out when you try to reassemble the gear set on the drum and it won't seat all the way.
IMPORTANT NOTE:
