Warn 8274 - Rebuild and Brake Assembly
Warragul, Victoria, Australia
G'day Guys,
I picked up an old Warn 8274 winch a few months back which I have rebuilt. During the rebuild I worked out a method of putting the brake back together that might save a bit of frustration.
My first attempt was less than successful. I put the main shaft into a vice, put one half of the brake on and aligned the ball bearings. I would then creep up on the beast and attempt to clamp it together. The slightest touch would result in the ball bearings rolling around and I'd have to start again. I repeated this process over and over and over again. At points I thought I was loosing my grip on reality, again and again lining up those ball bearings, as if something might mysteriously change and it would all go back together. I eventually gave up and went to bed.
During the night while asleep an idea came to me. In the morning, I raced back to the shed and within 5 or 10 minutes I had the brake reassembled and the circlip in place. No swearing, no yelling, no dog kicking. This is how the winch looked when I got it home. It had been sitting out in a paddock for a couple of decades. It is actually a 1977 model.
Cheers,
Ben
P.S. This is the project. His name is Mario and he is an '84 HJ47.
I had the body of the winch sandblasted and then powder coated and the hardware re-zinc coated. I sent Warn Industries an email and they posted me a bunch of decals for nothing. It was an exciting day in our household when a letter from Oregon turned up and the kids enjoyed googling 'Clackamas'.
The name of the bloke at Warn was Steve Schoenfelder, he was great to deal with and we swapped a couple of emails..............Steve owns an 8274 himself, unfortunately, he drives a Land Rover.
Ok. Here is how I assembled the brake.
1. These images show the conventional method. Note: the spirit level to try and stop the ball bearings rolling around........an impossible task.
Continued.......
This is the process I used.
1. Take one bolt. Size doesn't really matter. I put it in a vice, but you could just as easily balance it on a workbench.
2. Start assembling the brake in the reverse order. That is, you start assembling from the outside towards the body of the winch. NOTE: by doing it in the reverse order you use the larger spacer/washer to hold the bearings in place.
3. Once you get to this stage place the brake over the bolt and slowly tighten with the nut.
6. Align the keyways on the shaft with the brake and install the key.
7. Install the circlip.
8. Breathe a sigh of relief..........unless, I'm mistaken your brake is now back together.
And a couple of images of the front bumper. I had this old bit of 'C' section hanging around the shed for a few years, figuring that one day I would use it for something worth while. I made up a cardboard template and was going to have the 'Teq' symbol laser cut into it. However, I was so pleased with the service from Warn I decided to go with them.
The laster cutting used a bit of 3mm scrap to run a test on. After looking at it for a while I decided not to have the 'Warn' symbol cut into the mounting plate. However I cut it out and used it on the end of the bumper instead.
This is the finished bumper, back from powder coating. I reckon it looks ok.
Cheers,
Ben
P.S. And if you are wondering if the winch and brake works? Well I'm buggered if I know. The solenoid box is empty!
