Waeco CF50 issues - help wanted
I have the old style CF-50 with 5 LED lights, not digital display. This was awhile back but I think the temperature selection became non-adjustable and the lights would blink erratically.
Thanks I have the 'B' design with the digital display. The display read -18 and the fridge runs but never shuts off and the temp display never changes. So far I changed the board and tested a new thermister with no change.
Mine went through that phase once. It would only run turbo mode. I regulated it on that trip by unplugging it. I gave up on mine after throwing about $150 in replacement parts at it. Still have it if anyone wants parts off of it (make an offer). I'll have to de-solder 2 wires on the main PCB, but the controller/display PCB is easily unplugged.
Do you have the board in the picture below available?
It is inside the pictured plastic box
That's the only board I didn't replace because I couldn't find a source for it. I replaced the main PCB mounted to the end of the casing where the power plugs into and the upper control PCB.
So, yes, I have the original, but I suspect it is the primary failure in my case.
I found many sources but pricey
Im beginning to rethink going further
What is the part number on your board/black box?
I have parts available for CF-50
Still have parts for the CF50?
My CF50 is reading -16 F and runs continuously. If I switch it to Celsius, it reads +60 C. I think it is the thermistor that is faulty. If I unplugged the thermistor, it stops running and I get an ERROR message on the display.
