VSC TRAC VSC OFF
Virginia Beach
I’m troubleshooting the VSC lights on the dash and can’t get them to turn off.
I have had a few different codes intermittently triggering for O2 sensor and speed sensor but the only code I can’t clear is C1340 Center Diff Lock.
If I press the lock button on the dash I do not get the indicator the center diff is locked. I can hear the actuator working underneath.
I just replaced the position switch on the differential with no change and the old switch seem to test good continuity with a multimeter.
Hoping someone may have some insight. Please advise. Thanks
Have you tried moving the truck a little at slow speed? Sometimes it doesn't engage if the internal sliding parts aren't lined up.
I keep posting this but will do so here as well. I have 100 series where the same lights came on. Issue on mine was that the gas cap gasket was dry rotted and not holding a tight seal. Replaced it and all has been good for 3 years.
I don’t know if it was your thread or not I saw but my gas cap seems to seal okay. I can hear it release pressure some when I remove it for gassing up.
I’ve also been told that an exhaust leak or O2 sensor has caused the lights…. Not sure why those would have anything to do with stability control.
When someone stole my cats and cut my O2 sensors the lights did come on
If that's the only code you are getting and the actuator is working, most likely is the center diff lock sensor is bad.
That was the first thing I replaced.
Just jumped in and started it. ABS and BRAKE lights came on in addition.
Could the ABS module itself be bad? What fuses or relay powers the diff lock.
I’ll have to dig in the service manuals later today
Did you check/test the wiring?
Speed sensor looks to be dirt and corrosion inside the connector making intermittent connection. Hoping I got it cleaned good enough to return the new one.
This playing with the diff switch and that connector. Exhaust and drive train was too warm. The connector looked like someone tried dielectric grease inside.
So I tried jumping the 2 pins of the plug and only the VSC off light comes on and the OBD read detected no fault codes. Plug the switch back in and I get both lights and the C1340 is back
Are the indicator lights for PRNDL working on your instrument gauge/dashboard? My park and drive indicator bulbs were burned out and that triggered my VSC TRAC and VSC OFF lights. Replacing the bulbs turned off the lights. The electronics on this car are interesting, I believe the whole system is very sensitive to changes in resistance among bulbs and sensors, i.e. a bulb burning out on the gauge throws a light for the traction control system lol.
