Voltmeter on the dash
Panama
Hello guys, just to give you some ideas where to put a digital voltmeter. In the clock space.
I got a voltmeter and regulator and use the tablet and the led, a plasticglass and some glue, weld the + to the ignition so it will turn on only when turn your switch in acc and the - to ground.
Here how it looks.
regards,
Where do you locate your digital clock then?:confused:
A true outdoors man can look at the shadows around him and tell the time. Real me don't need clocks but obviously need volt meters.:)
.....1978HJ45
JChangFJ70, where did you source the voltage meter? Size?
Curious if anyone has used that spare spot under the vent - just to the right of the glow plug & filter lights. Not even sure why that blank plug is there. It looks like an ideal spot for a small meter.
.....1978HJ45
I guess if Mick Dundee doesn't need a clock no one does
1978HJ45 said:
Who is Mick Dundee?:)
.....1978HJ45
Crocodile dundee looks at the sun and tells that chick the time.
I know, I was just messing with you. Mick was that short crocodile poacher with the funny accent that married that good looking blond
lady from N.Y.:)
....1978HJ45
You are a real joker!:clap:
I used to own a LJ78 which requires a sense of humor and a high credit limit for unexpected maintenance.:)
.....1978HJ45
Hello guys, my 70 it was a work series that get to Panama, air condition and radio fm/AM. The dash board it has not a voltmeter, so Iook on marckhc his voltmeter and got the idea, i dont have a clock on that space.
Tomorow I will be on a trail, so no time to upload some pics of what I did on the back.
Regards
Why do you need an extra V meter where you are having one on the cluster?:confused:
To better monitor battery voltage and battery state of charge when running auxiliary equipment, such as an fridge or when truck sitting for long periods. For example a 12 volt battery at 12.2 volts is at 50% charge, but measuring state of charge from voltage is an approximation and should be temperature corrected
I installed a digital voltage readout, but it reads significantly lower than my handheld meter - so that might have been a waste of time. If you install one - make sure its accurate.
In the winter I use it when I'm plugging my glow plugs. I can tell by the voltage drop that my glow plugs are working correctly.
