I have q 71 FJ40 with the F engine it does have a painless wiring harness and Dolphin gauges. I was on my why home from a trip out west from St louis after driving straight through from Brice Canyon NP I made it to KC during rush hour. It was getting light out so I turned off my headlights my FJ started backfiring and died. I was able to limp off to the side of the hwy. I found out later that my voltage had gotten high enough to fry my electronic ignition I pull off the distributor cap and it had a very thick layer of black carbon dust covering everything. Well I had a to trailer it from KC to St louis. Since then I have replaced my ignition my voltage regular and my alternator and battery (to a gel battery) still if I drive at 60mph (close to 3,000RPMS) for any more that a few minutes my voltage spikes to over 16 volts. I have checked the ground of the regulator I even added a separate ground wire from the regulator case to ensure a good ground. I have the 3 wire regulator. I checked my engine, body and frame grounds all good. I thought maybe I gotten a bad regulator so I even purchased another one same result. I had driven my FJ 15,000 miles with no issues prior to driving out west so this was not an issue prior. My voltage is between 12-15 volts at 0-50mph once up near 60mph (3,000 rpms) for more than a few minutes and my voltage meter pegs over 16 volts. I have hooked up a voltmeter and it got to 17.5 volts before I turn on my headlight and brought the voltage down. If I turn on my headlights it drops back to 12-14.5 at high speed and between 10.5 to 12 at low speed 0-40mph. Right now if I have to drive on the hwy I keep my headlights on. I though maybe the pulley on the new alternator was a bit smaller so I swapped it with the pulley from the old alternator same result. My logic was first to change the regulator check the ground on the regulator still pegged the voltage, thought maybe the alternator was going bad replaced it still pegged the voltage, checked all grounds no issues. I do have electronic ignition and a high output coil but I do not think that would have anything to do with it. I would really like to get this issue fixed so any suggestions on where to look next would be appreciated.
