Rudi, suddenly I have no oil pressure. How do I test the Toyota 2F oil pressure sending unit?
I think my brain was getting in my way. I was confusing 3.4W with 3.4V and thinking the terminal of the sender was providing the resistance. I mean, a tail light bulb would do the same thing, wouldn't it? Maybe just not as bright?The bulbs in your cluster are 3W. If you have a voltage tester (screw driver model with wire) will do too.
Yes, the Dutchies are travelling Russia.
The bulb I had set up for testing is an old dash board bulb. I can read the 3 but not anything after that. Connected to the battery terminals it is bright. Connected to the oil sender, key on, no light. Start engine and the bulb is very dim, just barely glowing. Increase engine rpm, no change in the dim bulb.The bulb acts as a sender or as a gauge, depends on the test. A 5W bulb will do.
Your sender is......................................... kaput.The bulb I had set up for testing is an old dash board bulb. I can read the 3 but not anything after that. Connected to the battery terminals it is bright. Connected to the oil sender, key on, no light. Start engine and the bulb is very dim, just barely glowing. Increase engine rpm, no change in the dim bulb.
Yeah, but thanks for the confirmation. I think this is an anomaly unrelated the the other wiring issues. It just happened to fail. Curiously the day I'm to bring it home it won't start. Despite numerous wiring issues, replacement of points (twice, bad bushing no spring) we stuck an old used coil on it. A fully charged battery is the only reason I made it as far as I did. Fingers crossed I can find a oil pressure sending unit down here tomorrow, after I drop off the heater box and shift levers at the powder coating to re-do. One thing that is easy, just loop a piece of hose to the two lines to the heater box and you don't lose use of the vehicle. Can't shift it of courseYour sender is......................................... kaput.
But you figured that out yourself I assume.
Rudi
Is that something that can be corrected with a gasoline bath?Or........ the outlet for the sender is clogged.
Rudi
You need the help of a 2nd person. One let the engine turn over and you have a cloth to see if there's oil coming out.
I have a 6 wire VR. I will have a look at the contacts shortly and give it a clean.Hi Chris,
I assume you have a 5 or 6 wire VR?
That VR should not click when you connect the battery, if it does, the VR is malfunctioning.
Probably the contacts of the V relay (page 2 post #38) are causing the trouble.
Try to clean them with a little piece of very fine (500, 800 or 1000) sandpaper.
Rudi
Test: When you connect the batteries and you hear the click of the VR (= drain 0.3A) and you pull / disconnect the 6 wire connector of the VR,
does the drain disappear?
The one on the right in your picture is the V regulator. This one is activated by the V Voltage (the one on the left).
Clean all contacts from both relays. If that doesn't solve the problem..... try to find a (test) replacement.
