- Year
- 1987
- Vehicle Model
- 60 Series
- Location
- Palmyra, Virginia 22963 United States
- Mileage
- 323081
- Color
- RED
1987 FJ60, 2F motor, H55F 5 speed 323XXX miles. Asking $16000
The Good:
Runs and drives good, Just passed State inspection
cylinder head was replaced and galley plug fix and new valve stem seals. May 2019
Knuckles rebuilt 2019
2" OME heavy front/rear suspension installed 2018
ARB bumper and Warn 8274 winch installed 2018
31x15" BFG all terrain K02s 2018
ACC carpet installed 2018
driver's seat repaired and new foam done by local upholstery shop. 2018
replaced the RMS and oil pan gasket and cleaned the oil pick screen 2017.
The transfer case rebuilt flywheel re-surfaced new clutch, 2017
New AC compressor/condensor/expansion valve and dryer in 2016 and is working with R134a
new windshield and gasket
new belt line weatherstrip in doors
H4 headlights/ARB loom with relays and IPF headlight lens.
LED bulbs (green) in the dash gauges
LED interior lights and led light fixtures
window regulators replaced with Toyota OEM regulators
Trail Tailor aluminum dash bezel
Trail Tailor C channels installed in rear of frame.
Trail Tailor recovery points installed at front of frame under front bumper
TRF vents for D pillar
TRF headlight washer bottle, working headlight washers.
New brake booster, shoes overhauled, new front pads
Yaesu 2meter Ham radio in the sandwich hole
Uniden CB radio
Trailer hitch receiver
Saginaw power steering pump
62 door lock actuators and a remote lock system with key fobs. although right now only the driver's door works consistently (will need some lube to the other door linkages)
oil cooler was recently gone through cleaned and painted and new gaskets/rings heater hoses and piping.
The EGR system cleaned, new stainless EGR pipe from Specter off road, new modulator valve and EGR VSV.
Distributer refurbished with new o rings, grease, and teflon spacers, new yazaki plug wires and toyota coil. Igniter replaced with GM module
exhaust/intake manifolds overhauled. new gaskets, heat riser block off plate, studs, carb insulator.
Recently replaced exhaust pipes and muffler
The smog pump was deleted and replaced with an idler pulley. Air rail removed and plugged. ABV and smog hoses removed.
The Bad:
Needs body work along the rocker panels and rear quarters.
Needs a repaint. Clearcoat peeling in places.
cracked dash pad
small tear in the headliner back left. (see image)
paint and stains on the rear bench seat
Some cracks in the bottom of the plastic console. I have duct taped them from under the console.
The Good:
Uniden CB radio
The Bad:
cracked dash pad
