VintgeTEqParts FJ / BJ / HJ 60 / 62 Series Technical Solutions ........ (3 Viewers)
Lastly I have located a fist generation unknown diesel gas cap for USA spec bj and hi
Looks very heavy duty
And our latest diesel / JDM decals
This 60 went from having the usual starter click every other day to good reliable cranking.
If your battery cables are original, they are probably shot. You’ll be amazed at how well your electrical system works when your main connections off your battery are not only new but upgraded.
Tonight was a Big night of sorts , :D
a 3 + year quest to re-produce ,or Source simply the original OEM Factory Oil pressure
sending unit sender Black EPDM Rubber Cap or Boot if you will seams to be a Reality here as i put the the finishing touches
on the Sub-Harness that plugs into the main Engine bay harness .....
- mush mystery surrounds this little guy ,
- i have concluded it was introduced in 8/80- Later 2F 40/60 ,
- not sure about FJ6s 3FE ? \
- also on various other RWD Toyota Cars and Trucks with Mechanical Gauges
- it has taken be several years to amass my small pro-type construction u will see below ...
Sweeeet, good job there!! For sale?
Thanks For the Positive
i will post a Link very soon when i have good stock in a few days
my initial minimum order to avoid the Hefty Molding Fee , was 500-1000+ Pcs .........:rolleyes:
that hurt ................bad :confused:
but this is a Must have product from my mechanical point of view ...........
so stay-tuned , i have more in the near future pipe line coming Ya ..........too
matt
EPDM should last longer than the original rubber, too. So that's a considerable upgrade. I'll be ordering a cover and pigtail once you have them on the site so I can just be new all across when I replace my oil pressure sender. Want to pull off my oil cooler too so I can replace the O rings because they're leaking now as well.
A nice side benefit to the Oil Sender cover and lead -- It will keep people from trying to put the wire on the ground spade (instead of the round connector that you'll notice is isolated/insulated) and then frying the Oil Pressure Gauge....
Nice work Matt getting this made!
I want!
we have managed to source several / more then a few GLOW PLUG FEATURE Equipped ignition Locks key cylinders for
the BJ , and HJ 6# series folks out there , it seams Toyota has DISC. them globally ?
they can also be Re-Keyed / Re-coded to match the original 60 series key code among the the rest of the locks ...
For those of you that have had the need for either one of my Drive Belt Tension Kits #1 and or #2 , for either the OEM smog pump on a 2F or the Alternator
With the Valued help and Constructive feedback from both @Spike Strip & @whitey45 " THANKS GUYS ! " :D
i have Tweeked Kit#2 a bit with a longer carrage Bolt , from Japan , a different Lock down bolt , and added Toyota's famous Earth-Quake Washer or Collar some might say ?
Kit #2 now covers 8/80-1992 FJ40 and FJ60 , also FJ62 and FJ80 w/ 3FE Smog and Alternator individual belt tension needs and applications like clock work !
Please review photos below :
Here is the array of needed 100% OEM Toyota parts required to assemble Updated Kit # 2 .....:)
a few updates and then onto Gauging Interest
- FJ62 rear heater rocker switch Restoration service now available by appt. ,
- it might indeed feel like Vietnam outside right now ,. but winter is coming sooner rather then later ..........
- FJ62 Folks will be pleased to know that there precious ARACO auto body top tier quality brushed aluminum decals will soon be available
once again , in limited quantities at first do to a cautious street smart first run approach decision i had to make , so far im VERY impressed
with the quality and craftsman ship too .......... :)
- i also have available right now in the store , TOP Tier Quality reproduction power steering reservoir decals Chrome Foil Heavy Duty type
front face , and top cap lip semi circle ones , also in late late Model yellow and black FJ80 maybe ?
- lastly , i would like to begin gauging interest levels on a set of 2 reproduction FJ62 Glove Box Door face Decals ..............?
- are all 3 model years the same ?
- if yes great ,
- if not , why and who has a live sample to borrow ? :D
- my live reference specimen model year below is unknown ?
any input , feedback or help with the glove box door model years topic would be greatly valued ........
thanks
matt ...
my first shipment of OIL pressure sending unit Rubber Cover Boots arrived today via DHL ............. ✈ :D
I want!
Hahaha, knowing this I still managed to fry my gauge accidently. I've been waiting to see if this cover would ever be reproduced, mine fell apart several years ago.
Great to know that you're getting this cover reproduced Matt. Thank you for your efforts! I'll be be buying two when available.
Thank you,
Gil
