VintgeTEqParts FJ / BJ / HJ 60 / 62 Series Technical Solutions ........ (5 Viewers)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
Welcome To the :
VintgeTEqParts 60 / 62 Series Technical Solutions Tread ....
Ever since i was a teenager growing up in the 1990's , i have had a passion for
anything TOYOTA , Especially Anything Involving Toyota Genuine Parts
MADE IN JAPAN
Im greatfull for the opertunity to have and share what i have to offer , and help better
explain the How's , Why's and General TECH. behind the ever growing Diverse Lineup of
Both Custom , hand made in our " Skunk-Works " Prototypes Shop on premises , and
the hard to find Nitch OEM and NOS parts Products My wife , ( life Partner )
are continuing to search the globe and bring to the table ...
and I have to offer the 60/61/ & 62 Communities and a whole !
This will be a ever evolving Tech Thread , however i will post a Link in each
Parts Offering to be directed to Our Online parts store ,
We are both VERY Proud to be coming up on us Celebrating our 1st year in buisnes
Here Beginning in April ,
Serving The Entire Land Cruiser Community as a whole ......
It's both Humble Privilege and Honer To be able to to so !
Thanks For Your Support !
Kindly Erin & Matt .....
I have been giving must thought over the last few weeks , on how
to begin this thread , and with what Technical Repair , Restore ,
upgrade and update products and services we offer 🤔
so i settled on one New set of items that cover and the bases , and
we developed and now make in-house by hand 100% in our " Skunk-Works "
Shop .........
I wanted to and always do want to give land Cruiser owners across the board the
Highest Quality , most well thought out and very much intentionally OVER-ENGINEERED
products i possibly can , and our new Line of FJ60 Battery Cables Will be no different !
I realized a while ago that TOYOTA had Discontinued ALL 60/62 OEM battery Cables
So , i saw a opportunity to put what i Learned during my Tenure In the T-TEN Program
and apply some good old USA TOP SHELF MARINE GRADE parts in the mix too ,
to create a set of related Products that Exceeded Toyota OEM Specs in every way , and
More importantly would stand the test of Age , and Time !
Now 8/80-9/87 FJ60 Owners will have a Choice between Pep Boyz , Rock Auto , and
100% Made in Japan parts , and also ANCHOR marine grade industrial Parts Combined
in Harmony in the form of Battery Cables Both positive and Negative , ones ,
including the little know about Starter Ground Strap called Cable , Bond No. 1............
Here is the Technical Spec's as follows :
- Toyota only used 4 AWG cable , i have upgraded to 2 AWG , both positive and negative & Cable Bond #1 starter strap
- The positive side cable terminal is a late Model L shape , just like a Modern Land Cruiser , so the cable coming off the Serviceable and indeed removable battery side
Lat model Terminal dives right down out of the way , i also applied a high heat split loom jacket w/ blue 3-M electrical tape to model a later updated cable
- The Negative side is split into 2 cables instead of the poorly designed spliced single
original pigtail design , so my Short negative will secure to the passenger side Fender
with ease ........
- I design ALL my products to as Plug and Play as Possible , including ALL needed and necessary Made in JAPAN OEM Toyota mounting hardware .
- Cable Bond #1 Will include a new starter Bolt and spring washer , and also the
needed long 40mm x 8.25 top pass frame rail vertical bolt .........
- I use Full Synthetic Di-Electric grease on ALL crimped LUGS
- Also , Heat shrink that is adhesive Lined and BOMB Proof solid water tight ...
- I would like to take a Moment to thanks my Solid Friend @4Cruisers , John
Loaned me the Doner original set to make my First Production Runs out of as a template if you will
- I will Always try to incorporate a Dedicated Factory Parts Diagram in relation to the topic and parts at hand , so Fellow Members can understand things on a greater level
Cable Bond #1 ..........
Comes with a 5 pc Body strap ground kit as well , NOS Genuine Toyota Parts
- OEM mounting Hardware
Another Long time coming to the table has been a recent addition , the Rear Washer
Bladder Bag , Pouch .......
- i hunted the globe and finally have established a contact with OEM parts Maker Nippon-Denso in JAPAN , this is nothing less then HUGE !
- TOYOTA has DISC. the pouch here in the states , but it can be still HAD in a Very Complex OEM plug and Play KIT form ...........
- i test fit this in a 1989- FJ62 and it's SPOT - ON ! ,
- comes with a JAPAN , 12v MOTOR , I WILL have 24v Volts Options in hand ant time now for our HJ and BJ Brothers and Sisters too ..........
I work on a lot of stock 60's, and most with the original worn out battery cables causing issues, I look forward to trying your kits.
I'm shocked @ToyotaMatt wasn't already using the Yazaki tape
Fresh Set or Cable Bond No. 1 Kit's just finished up ......
