Wanted Valve cover nuts for 73 1f.
I have Marine Grade .316 Stainless Steel Acorn style nuts
as long as u are still running the OEM original factory black sheet metal steel valve cover 1F engine with original OEM cork style thickness
valve cover gasket , & OeM toyota Grommet Seals ...
These Look sharp oem toyota like a 2F , NOT shiny chrome , will never rust , also 12mm hex tool size same as oem toyota
the solid acorn cap has a few mm /milometers of room to spare as long as u run ALL oem toyota thickness parts outlined above ...
I have the nuts and studs u need and a brand new oem master overhaul gasket kit and new in box thermostat and several other parts for f engine
How much do you want for the OEM nuts?
