Vacuum test steps (with video)
Los Angeles
Hi Everyone. So, as I continue to get my truck ready for a smog test, I decided to do a vacuum test as instructed by the manual. All feedback is welcome.
The steps in the manual are as follows:
The desired readings are assumed at sea level. If you are at high altitude, the reading will drop about an inch of mercury for every 1000' of elevation.
Allow the car to warm up to normal operating temperature
Connect the vacuum gauge directly to the intake manifold port
The vacuum reading should be between 17-22 in-Hg with a steady needle.
See video and additional information from the manual below.
Vacuum is excellent. No vacuum leaks. When checking vacuum, it's what the engine is doing at idle that's important. Goosing the accelerator won't show you anything worthwhile, though it's fun to watch the needle drop. Just warm up the engine maybe 8 minutes and let it sit at normal low idle & watch what the needle is doing.
Yours looks great.
Set the idle to spec, test vacuum at idle - But looks good from the vid.
Get the proper Air Cleaner wing nut with built-in gasket and keep crap out of the carb. Part # 90175-06003
Do you have the gasket that goes between Carb Air Horn and Air Cleaner ?
17848-61020
Be aware, it has a groove that allows it to be fitted onto the bottom of the Air Cleaner - it doesn't just rest on the carb.
Any vendor should have it as well as Toyota
Sorry for the totally novice question, but where is the intake manifold port that you're connecting the gauge to? Got a photo? Thanks!
A/C idle up port works well. Just remove the hose that's on it. Replace after vac test.
vac-port-for-vac-gauge-jpg.942346
