So I did a SBC (TBI) swap a while back and I'm considering going with an Aluminum Rad and I wanted to see if anyone who has done the same has feedback on the difference between the stock rad and the alum. V8 replacement.
I notice I run at normal thermostat temp when the outside temp is 80F or below, but when it gets into the 90s and above I start to run hotter (195-200).
I had a good shroud fabricated and I seem to be moving the air well enough, but once I added the winch the temp increases on the freeway.
I havent hooked the A/C back up yet because I want to get the cooling under control first.
Some folks have posted no cooling issues on 100+ days using the stock rad, but my temp seems to creep up on me on the freeway cruising at 3K rpms. I brought the rad into a rad shop and had it checked for blockages before final install and the guy said it was good to go. Its a CCOT rad about 4 years old.
I've swapped thermos to a stant high flow and there was no change.
I'm running a milodon high flow water pump and a Hayes heavy duty fan clutch
So I guess I'm wondering if the V8 alum rads are really worth the cost?
Thanks,
Bryan
Thanks,
Bryan
