Pics of 60
kind of crappy pics and showing off the fan shroud I did a number on .
GM OEM Fan clutch is about 1.5 inches from the radiator core.
I don't have much room to work with, notice how forward the engine is relative to the radiator core.
I plan to get my freind to build me another shroud...based loosely on design I see here
http://sleeoffroad.com/project_vehicles/v8-80/v8-80.htm
see pics of fan shroud (scroll down the page) and also based on similarities to the GM shroud below.
My current setup is not the greatest, the fan is about 1/4 in the shroud and 3/4 out, I have concerns about the flat portion of the shroud blocking air flow across the full core.
I modified the lip of the shroud and it looks like crap, before I cut it down the lip extended back quite far and I was concerned about the fan's ability to pull air. While it may seem crazy...the fan seems to work better now than before. Which is kind of unsual...when you see the pics in next post with teh stock gm pickup where the fan is about 100% inside the shroud.
Sorry to take over the thread...but seemed like a good place to debate V-8 cooling solutions and design. I went and looked at the rock auto web site...it looks like there are different GM fan clutches for the 1999 year model GM pickup/suv with 5.7. It also appears that for the 2007 year model 2500 HD there is only one fan clutch ...GM OEM setup. I think I may have made a mistake in something I said elsewhere....not my intent to mislead anyone, other source reference...shows for the 6.0 engine.. two clutches one with air and one without, different sites show thermostat to be 187F too for 6.0 engine.
Ok since I asked others I should make the same notes: 1986 FJ60, 5.7 vortec V-8 from a 1999 GM pickup-SUV, A/C is operational and condensor in place, radiator is aftermarket 4 core brass replacement type, fan and fan clutch match the engine both are new GM, fan shroud is home brewed but does block some of the radiator core and I plan to fix that, I screwed the shroud a little bit when I cut on it, 195 thermostat, green coolant,
In winter truck generally runs around thermostat temp 195 F, In summer without a/c it will run 195-210 and under agressive driving will climb to 220 (6Krpm runs at times) on the road in teh summer if will climb up to 220 or so at 65mph which I think it on teh edge of too hot, it will cool down at idle without an issue, an noted at times the fan clutch seems to have a mind of its own.
Extra info.. 5 speed manual, 4.88 gears, currently 33 tires, lockers etc.. I have a winch but it does not really block the air flow, I also have a p/s cooler in front of the condenser but its not that large to have any real impact on cooling.
One thing I should also make note of is my radiator modifications. I don't recall now but the radiator had 1.5 hose connections and I think my GM engine hoses were 1.25 or vice versa, so anyway I had the radiator modifed to match the hoses. I also ended up moving the lower radiator hose connection to the far passenger side of the tank, because I had clearance issues with the lower radiator hose and the FM fan. The GM fan is roughly 19.5 in width and you can see the single belt drive that is stock on this particular 5.7 vortec. I have added a larger alternator (CS144) which was an option for these engines.
My engine does not sit exactly square with the radiator but its about as close as we could get it and clear the driver side frame/ p/s. To get it totally square would reequire the engine to move to the drivers side another inch or two.
