in the event the shaft needs to compress in length quickly, it won't be able to because the grease will not be able to escape fast enough.
when is this going to happen on an 80?
IMO, If you don't have a grease ring at the slip yoke you either
1. using the wrong grease
2. have clogged splines
3. aren't pumping enough grease in during servicing
#3 will lead to clogged splines as grease in those splines is allowed to sit for years and dry out and restrict new grease if at some point someone starts to grease the shaft properly.
When greasing the splines I pump in grease to the point where the shaft starts to expand. And the truck tends to stink for a bit afterwards as the grease expelled from the slip yoke lands on the muffler.
Any help?????
Hate to bump a normal thread... but I guess it is better than starting new thread.
Did you completely depressurize the drive shaft? The 18" noodle may not have been enough.
Dave,
Been reading this thread with some mild interest. I had this problem occur in a FJ55 the first time I greased the truck myself after I bought it. Overdid the greasing and got the moan from underneath. After consulting with some gearhead friends, releasing a big noodle of grease solved my problem.
That was then, this is now.
So you still have the noise even after taking the zerk loose? If so, I suggest dropping one end, taking the zerk out and applying more pressure on the driveshaft to make sure there is no pressure at all from the grease still putting pressure on the TC output bearing. Then replace and test drive again.
I doubt that the short time you ran the truck before releasing the pressure in itself would cause damage to the TC output bearing. However, it may be that you or a PO were putting some pressure on the driveshaft already and the latest lube pushed it over the edge to failure. Hope that wasn't the case, but don't beat yourself up over it either if that might have been a factor.
GL
Could be your UJs...
Mine felt good on the DS but when I pulled them apart you could see the brinelling on the races. Stuck in new UJs no more - grrr when on or off the gas.
