Yesterday in the process of continuing the baselining of maintenance on my "new to me" 80, I changed the gear lube in both axles and transfer. The oil was generally in good shape. Transfer drain plug had essentially nothing on it. Front diff plug had a little bit of the normal "fuzz" and the rear plug had a bit more. What was interesting was that drain plugs on both diffs had larger pieces of debris. The rear had 4 and the front had one. They are clearly the same things, but for the life of me I cannot figure out what they are. Am hoping that someone here has seen this or has a clue of the source of these items (pics below).
Background:
1994 FZJ80 with 188k miles. Appears to have not been wheeled. Factory elocked. Fairly good maintenance records from the first two owners indicating reasonably recent (3 years ago) gear oil change and consistent changes over the rigs lifetime (so far). No noises in any gearbox. Both lockers functional, read indicator light not functional (but tests show actuator working AND rear locker is locking the axles ... I have not checked the switch on the housing yet, but am 99.99% sure that's the culprit). On draining, all oil looked to be in good shape: dark colored - yes, but no metallic sheen or water mixing evident.
What I found:
Rear diff had 4 of these objects - 2 intact and two folded over. Front had one of them intact. They appear to be about 3/8" in diameter, circular, made of spring steel or sheet metal, in a dome shape with "nipple" in the center, and just a few thousandths thick and the edges are sharp. They are not easy to deform.
As I said, they look vaguely familiar, but I cannot place where I have seen something like this before. I cannot think of what the origin of these things might be in a differential, but am hopeful that someone here might. They almost look like something a set screw might bear against (or maybe a detent ball).
Now for pics:
Looking forward to all input.
Background:
What I found:
Now for pics:
... I am still cornfused as to the source.
