Unobtainium (3 Viewers)
The air cleaner intake hose for '75 to '78 FJ40 is now in stock. Please check the posting in the Storefront if you're interested.
what about the two air cleaner gaskets beno still had the small round one but cant locate the lid gasket or the one under the filter element?
I'd focus on the one that sits below the filter element. The lid gaskets are easy to make from hardware store weatherstriping. There should be a link for that in my sigline.
great job on the step!!
i take it that you would be able to fit a receiver between like this photo (see below) .... if its a style that is up against the frame like this ... like Mark A and others offer
pic from IDave
I don't have that receiver, but the distance between the bottom of the rear bumper and the stepping surface of the rear step is about 4 inches.
Ok - measured my diy receiver plate - which is larger and heavier than pictured above - should have about 5/8" of clearance to the step so it shouldn't be an issue . 7" from the bumper should work as well , although the receiver mount may interfere with the use of the step a bit , but overall better than trying to use the bumperettes to get into the truck . Old , screwed up knees and limited range of motion really sux getting in the back ..
Sarge
In Johnny C's picture one side looks even with the bumperette and the other looks longer, optical illusion?
I need one.......
Early 70s windshield washer fluid bottle? Those seem to be gone at any normal price. Perhaps too complex would be the discontinued early 70s front door seals.
No idea on the demand of either since those products changed around 75.
  • Back
