- Thread starter
- #161
Mirrors - how about a mirror that works with the OEM or after market arms that are intended for the plastic mirrors that almost universally fail. Frankly what I would like is a mirror that looks similar to OEM but has a better method of clamping on the arm ball - the OEM and after market versions of these fail.
I'm generally a purist, but one original item I never quite liked is the stock mirrors. It's not only fragile, but requires frequent adjustment in daily use. As mentioned above, aftermarket mirrors aren't better, just cheaper. With that in mind, I decided to carry the elusive, frequently talked about but rarely seen, rarely available OEM Euro spec mirrors...on an as available / trial basis. These are really the best mirrors Toyota ever made for the FJ40. It's a direct plug-and-play replacement to the stock mirror. You can even re-use the original gasket. As some of you already know, these mirrors do cost an arm and a leg
. I have done my best with the price (check my sig), but consider yourself forewarned!
