Unidentifiable vibration felt in floor and steering wheel
87warrior
Whiskey Tango Foxtrot
Junction City, Kansas
I know diagnosing a vibration online is difficult but I am in need of any help as I am loosing my mind. My stock (with exception of a Bud Built transmission skid) 2016 with 175k miles has a vibration and groan (woo-woo-woo sound) that starts around 55 mph and stays pretty consistent up to 80 mph. It has slowly been getting worse over the past couple of months. It's felt in the floor board and steering wheel and kind of feels and sounds like a front wheel bearing going out. I did remove the skid plate to eliminate that as a possible source.
The vibration and groan seems to go away (or lessen) when taking a long sweeping left hand corner. There is no change when braking. There is no change with the center diff locked. This weekend I replaced both front wheel bearings with prebuilt assemblies from Cruiser Outfitters with absolutely no change to the vibration/groan. I've done a 5 tire rotation and pried on the ujoints to look for play and greased the driveshafts. I have lifted each corner and pushed, pulled and pried on the tire/wheel to look for play and have found nothing.
Since this vibration/groan changes with cornering, I wonder if a CV could be going bad. They aren't throwing grease, the boots are 100% intact and I don't hear any clicking when making tight turns at low speed. I pushed and pulled on the CV shaft and didn't notice any play. Of course I did not pull the axles out to check them when I did the wheel bearings as I didn't suspect them at the time.
Has anyone else experienced this? What am I overlooking?
Universal joints?
Similar symptoms for me around 150k, turned out to be a rear axle bearing. I spent months checking all kinds of things, eventually putting the vehicle on jack stands and letting the wheels all spin in S1 in the air while using a mechanic's stethoscope to try and find the source. No dice.
Chassis ears ended up being instrumental in tracking this down.
In my case the reason the jack stand trick didn't work is the damage was on the top of one of the outer bearing races so with the wheels hanging there was no load on the bad area.
A quick but not definitive way to check the rear axle bearings (if you don't have much corrosion) is to pull each of the rear ABS sensors and look for evidence of scuffing on the end of it. If everything is working right there shouldn't be any marks. As the rear axle bearings wear it allows axial slop in the assembly and you'll see scuffing.
My scuffed ABS sensor
overall adventure of finding the issue
process of changing the bearing
postmortem of old bearing
@LTSR and @CanadianRockyCruiser - I have more experience than I'd like to admit with failed ujoints in my Jeeps and this doesn't seem the same. The oscillation sound/vibration the 200 is making remains 100% consistent regardless of throttle or brake input. The only time it changes is when cornering to the left, whether on or off the throttle.
@bloc - The description of the sound your bad rear wheel bearing made is pretty close to what I am hearing. The difference is I can also feel it in the steering wheel/floorboard and it changes when I take a long sweeping left turn. I am going to pull the ABS sensors to look for any scuffing. Thanks for pointing me in that direction.
Definitely worth investigating the bearings. Miles are high enough to consider it a possibility. Chassis ears for the win.
I pulled the rear ABS sensors and did not see any scoring or marks on them.
I have started investigating with wireless chassis ears, but have not been able to pinpoint any issue. I've hooked the microphones to the left and right rear wheel bearing mounting bolts, near the rear pinion on the diff, near the rear transfer case output, near the front transfer case output, the middle of the front diff, both sides of the front diff and both front ABS sensor mounting bolts. Nothing-nada-zilch. I listened at high speeds, at low speeds and while making sweeping left and right hand turns. I'm sure the neighbors up my county road are wondering what the heck I am doing.
My next step will be to pull the driveshafts and see if there is any change.
Dear wife has been driving my 100 instead of the 200. She says it isn't terrifying to drive like the 200 is right now.
Sounds like you're doing exactly what I would. In my case when I found the bad rear bearing it was painfully obvious.
If you drive it in the rain with only the rear driveshaft in, be warned.. between the power, short wheelbase, and suspension travel.. things can get quite squirrely. I had to do that for a week while I was replacing my u-joints.
Slow Update: I replaced both CV axles with no change. I have also pulled each drive shaft and experienced no change in the vibration/groan when driving. Boy howdy, it sure is fun to drive in rear wheel drive!!! I even left the engine skid and bud built transmission skid off just to make sure those weren't causing a problem. I think rear wheel bearings are the only thing left to change.
I suspect my next post will either be a successful rear wheel bearing swap or what I traded the 200 for.
Potentially dumb question here but did your tire rotation include balancing?
And not just balancing, because a broken internal bead in a tire can make odd sounds in addition to vibration. Ever hear a vehicle going down a road nearby making a wump-wump-wump, almost thumping sound?
