Ultra gauge mounts (1 Viewer)
Outsane
Supporting Vendor
San Mateo, CA
Website
solvefunction.com
I made some ultra gauge mounts kinda like the schnauzer mounts.
Also a ram mount version
This would also work well with the a pillar mount from @NLXTACY
Would it be possible to modify this to mount a Holley 3.5” screen?
I had my ScanGauge II in that center spot and it blocked the 2nd Start/Power indicator, which was a no go for me. I toggle between 2nd start and Power all the time when I'm on the trail, and I need to be able to see those. Maybe this one doesn't block those, but it's worth considering.
Looks like a good product otherwise.
Just played with the scangauge, I could make a mount to attach to the cluster in a spot that would be low enough to keep all the lights visible. Instead of mounting to the steering column. Only issue is that you could not tilt your steering wheel all the way up. Also height dependant
