UC chat (10 Viewers)
Most military tires are also steel carcass instead of nylon, so they'll likely be much heavier, which would stress everything that much more.
It is fixed, was a blip in the Googleverse.
Is 16.5" wheels a common size? Guy on cl selling military tires 200 a set. Think they are 36's so body lift would be a must for me.
IF you are going this route... http://www.militaryoffroadtires.net/. Inexpensive wheels and tIres.
EMS Powered sells a wheel adapter to bolt a dual bead lock humvee wheel directly to an 80.
You would have to contact them about fitting on a 40 or 60.
Found some 35's on craigslist for 150 but they are 12.5 wide. I talked to the owner this morning but gonna wait.
You're going to do some serious lifting to fit 35's
I have a body lift, just not installed.
19 axles under that badboy. Delivering part of the press.
Part of a new press being delivered to the plant. 2 of them came in. In the middle of the trailer someone can steer and also at the very end. It was so long that they had to back it out of the plant.
Those military tires are probably the old style Goodyear MT. Guys run them but not the best option, 16.5 are known for slipping off the bead without beadlocks. I would pass. What size rim are the 35x12.5? That is the most common width so not sure what other size you were hoping to find.
15" rim. I contacted fj80 about those 17" marsh wheels. Thinking about going that route.
We wheeling this coming weekend or what? Hoping axle is done and i can come out Saturday.
Just let 60 temps go. How launching new car though. Might be hiring in couple mos. Got to start as temp though.
Similar threads
