U-joint part numbers for 1999 LX470
Corpus Christi, Texas
I have been searching on mud and different parts catalogs and getting conflicting info. Does anyone have the part number for the front driveshaft rear u-joint part number? Is it better to just replace the entire driveshaft or are we good to replace just the u-joint? Thanks a bunch
Front drive shaft does not wear out as the rear because it is connected to a frame mounted diff, so no flex as the rear. I installed both front and rear OEm drive shfts but found out front is still has no sign of wear in U joints or splines.
For the rear, the rear most U joint and the splines wear out. You can find part number here: add your vin and search: partsouq.com
