Yawn.
Perhaps you can enlighten us with all the details of your setup. This will maybe show why your fuel economy compares to Graeme's 100 series with over 800Nm or my Isuzu powered rover with around 550Nm with either vehicle towing another car on a trailer.
I have run with backpressure gauges, I'm not guessing at figures. I know what they were.
Cold acceleration, double boost (40psi drive, 20psi boost).
100km/h cruise, ~1.5 times boost (12-13psi drive, 8-9psi boost).
2000rpm full torque, drive is under boost (18psi drive, 20psi boost).
I'm not biased, I present the facts which include how much power it takes to run a supercharger. These show the problems superchargers have on diesel engines.
You have presented no facts or data at all. Except for fuel economy figures which can be beaten by petrol vehicles.
Put drive and boost gauges into an 80 series and I'll tell you exactly how much power the turbocharger is using. Along with how much comes from heat and how much from pressure.
One thing I can guarantee up front. They'll **** all over the results of a supercharger on the same engine.
How much power it takes to get the same airflow through the engine would be a more valid comparison, because you can get the same airflow with less boost when running a more efficient exhausting system, a percentage of the power lost to drive the crank driven charger is gained on the more efficient exhaust side. An engine that has been optimised for a turbo won't show optimum results with a crank driven charger when the engines breathing requirements are designed for a turbo system. I think that it's reasonable to assume that the large majority of folks in this forum drive 4wd's that get close to these consumption figures, some better some worse, the money saved by not buying a more expensive newer (or new) vehicle can buy a huge amount of fuel, so losing 10% fuel efficiency is worth it if it means that the laggy old turbo diesel gets transformed into a beast and is kept because it is now great to drive , but thats just my opinion, obviously people make their own choices.
I see you have already decided that the turbo figures will "**** all over the results of the supercharged engine" , I'm obviously conversing with the wrong engineer here, I'm really looking for someone who has optimized their engine to suit a crank driven charger, and "results" include the drivability of the engine in question.
