crushers
post ho
cool, good to know. thanks
That's funny, because your timing, chosen handle and comments say exactly the opposite.I'm not here to argue with you Mr. Dougal
just pointing out the po0tential of a supercharged diesel engine. The street diesel engine and modern supercharger are a great match. Maybe you would like to email Gale Banks and tell him that his supercharged engines are smelly and lack power, or explain to the Renault engineers that superchargers don't produce economy or top end power, because you can devise a calc that says so, It's time to let go of past misconceptions and enjoy what modern technology has to offer.
the problem is that there isn't a lot of info on supercharging diesels as yet
Drivability is extremely good when the engine is always on boost, well worth the small drop in fuel consumption in my opinion.
I'm not here to argue with you Mr. Dougal, just pointing out the po0tential of a supercharged diesel engine. The street diesel engine and modern supercharger are a great match. Maybe you would like to email Gale Banks and tell him that his supercharged engines are smelly and lack power, or explain to the Renault engineers that superchargers don't produce economy or top end power, because you can devise a calc that says so, It's time to let go of past misconceptions and enjoy what modern technology has to offer.
The O.P. has an older engine, how many people on this forum would be running a 2011 or 2012 diesel in their rig probably 1.....the later turbo diesels may be much better when it comes to turbo lag, but I can't see him fitting the computerized engine management system when he's after a system that can live through being immersed in mud/water. Economy isn't mentioned either, he is asking for a system that produces torque on demand, which a supercharger does very well.
I have driven a few different turbo diesels over the years, the 2004 mazda T.D. that I drove a year or 2 ago had about 4 seconds of lag before the turbo started to produce boost, the 2010 transit van had a good 2 seconds, and thats just the start of boosting, full boost took quite a bit longer. There is a good reason that engineers are trying their hardest to develop electrical assist on turbo applications- if you want instant boost you can't beat a crank driven charger.
As far as fuel economy goes, I expected to get horrible consumption figures after I fitted the rootes blower, I mean it's well known that the rootes design is at the low end of the efficiency scale, and there are rumours going around about how much of a parasitic drag these blowers supposedly are, yet I only dropped 1.5 litres per 100 k. I didn't drive for economy, it was such a buzz to have a powerful engine under the hood I made the most of it. I often took of from a standstill in 2nd gear as first gear was now too low- around 2 seconds from standstill to high revs along with substantial neck strain, if I was chasing economy then lower numerical diff ratios would have given better figures. Another huge benefit of running positive boost at idle was that I could now run multi fuels, even used/filtered engine oil burnt very well when injected into the chamber, along with used cooking oil etc.etc. All of a sudden it became apparent that it was much much cheaper to run on free fuels when supercharged....you can't do this with a turbo without getting large amounts of white smoke when boost drops off, so in the real world superchargers have many advantages over turbo's , well worth a try!
It might be a good time to consider why engineers are developing electrical assist on turbo's Dougal, maybe you could help them to save a few million in development costs with your no-lag calcs! Like I already mentioned earlier, when running a supercharger the increased in-cylinder pressure at idle is sufficient to run fuels other than diesel, like used filtered engine oil, with no visible smoke emitted from the tailpipe. Used engine/vegetable oil is usually free, costs a few cents a litre to filter, which puts the crank driven charger in the most economical system to operate category. The white smoke comment that I made referred to a turbo engine trying to idle on used engine oil, with no boost there just isn't enough heat in the chamber to burn it properly.
In the mid 90's engineers were playing with electrical assist turbos.
Since then I can't name two production engines with it. It's simply not used.
In my immediate family we've got 8 diesel cars, ranging in age from mid 80's to late 2010.
Of those one is a computer controlled sequential/compound system.
Three are computer controlled VNT turbo's.
One is a vacuum controlled VNT turbo.
Three are wastegated turbos.
None have a lag problem. What are these lag calcs you are on about?
No-one in their right mind runs used engine oil through their injection pump.
As I already stated. The white smoke at idle means your injection timing is too far retarded. Advance the timing and the white smoke will stop. No supercharger needed.
Do you have anything real to add to this thread?
Data?
Performance figures?
Production supercharged diesels?
Because if not, you're just wasting everyone's time. Just like Roscoe was earlier.
The electrical assisted turbo is still being investigated, here's some info from 2007 Browser Warning
Here is an article that includes some graphs for transient torque response, note the big improvement with the assisted turbo! Browser Warning
Quite a few people run used motor oil through their pump/ engine nowdays, it lubricates the pump much better than low sulphur diesel, and please don't tell me that your uncles fathers wife wrecked his pump doing this , if the oil is properly filtered then it would more likely extend pump life.
White smoke at idle.....I dont get white smoke at idle , so there is no need to change the injection timing, when I run heavy oils for fuel I get white smoke at idle when running a turbo, because there isn't enough heat in the chamber to burn heavy oil, when running a supercharger the boost at idle provides enough heat to burn the heavy oil-hence no smoke!
You must sell turbo's for a living, you sound like a dodgy used car salesman with your lagless turbos and incorrect calcs!
Still hasn't made production and likely never will. It's not relevant to this debate.
When oil is considered too dirty to run your crank bearings, why in **** would you want to run it through your injection pump and injectors? The two closest tolerance and most expensive parts on your engine.
You would have to filter it to clear before all the abrasive carbon particles were removed. I can guarantee you aren't filtering it that well.
Do you understand the relationship between compression temperatures and injection timing? Your response above says no.
Essentially you have fitted a supercharger to an undisclosed engine and taken a ~15% fuel consumption hit because your timing was too retarded for the fuels you were trying to
Nope and I don't believe you understand any of the calcs well enough to call them incorrect.
Can one of the mods please lock this topic?
Because a new technological turbo assist prototype hasn't made production by a larger scale manufacturer doesn't mean anything , much, more time and dollars should improve efficiency/build cost for what is essentially a crank driven supercharger.
FILTERED used engine oil is fine to run as a fuel, if you can't work out how to pump it through a 1 micron filter then that shows your lack of practical application down here in the real world! I wouldn't run it through a turbocharged engine though, there is too much unburnt fuel left over after the combustion event, hence the clouds of white smoke when your turbo does a seal and starts blowing engine oil into the intake, a crank driven charger can allow FILTERED used engine oil to burn completely , great economy there!
Calcs: Tell me how you calculate the parasitic drag of a turbo system please, pumping the exhaust gas into a 20 psi manifold requires quite a few horsepower, let alone into a manifold with 40 or more pounds per square inch, yet you consistently leave this loss out of your equations! Please explain !
Perhaps you could give me some camshaft timing figures suitable for a 8-1 pressure ratio engine, (that would be 8 pounds of boost and 1 psi exhaust backpressure), one for horsepower and one for economy ! 2 cams to try.
Horsepower costs fuel, if you want to go faster you have to burn more fuel, it's simple really!
The fuel consumption drop was from 22.5 m.p.g. to 20.1-that would be a 10.6% drop, how did you calculations get you 15%? You are 33% out on that one!
It appears you haven't read a single word I've written. So I'll write answers below which say exactly what I've already written in this thread.
They haven't made production on any scale and likely never will.
1 micron filters will not remove the abrasive carbon particles which colour used engine oil black.
You need to filter the oil until it is visibly clear to remove those, you are clearly not doing this.
Turbocharger seals do not function in the way you think they do, nor does combustion on a healthy turbo engine leave unburnt fuel.
It appears you have no idea what exhaust pressure turbochargers run at. Suggest you read this thread as those figures have been stated.
Turbochargers at best points run higher boost than drive pressure. As Graeme has stated in the applications he has looked at a turbocharger requires 1/5th of the crank power that a supercharger requires to deliver the same boost.
What are you on about now?
A more efficient engine produces more power from the same fuel. Turbocharging makes engines more efficient.
That is appalling fuel economy. I thought you'd be getting roughly what I get.
The typical diesel engine oil is full of carbon particulate, and yes it gets pumped through your bearings, particles of 1 micron or smaller arn't really of consequence , thats why the standard fuel filters on most diesels don't filter to a particle size below 1 micron and typically filter from 5 to 10 microns.
Combustion of fuel in the typical mass produced automotive diesel engine isn't 100%!
The very large majority of diesel engines in use have much higher backpressure than your willing to admit, but if you want to calculate your figures to suit a laggy aftermarket set-up then your figures are of no use to anyone much .
The fuel economy figures are typical down here in the real world, much more common than your downhill coasting with a tail wind fuel consumption figures. I can get much better figures by dropping cruise speed and driving for economy, but don't.
It's obvious that you have a bias when it comes to the turbo vs crank driven charger discussion, what a shame, a lot of people here would like to see an unbiased comparison so that they can make their own minds up about which type of charging will suit their application/driving conditions. If you can calculate the power needed to drive a crank driven compressor then why not do the drive loss figures for a TYPICAL turbo set-up, like a 80 series cruiser for example?
