Is there such a thing as one that accepts 3 inch OD pipe?
Yes, there are plenty of benders out there that will handle 3".
.......but they are not manual machines. Let me know if you would like more information.
I'd like some more information as far as projected costs. I'm not an exhaust shop, I just have a requirement to bend 3 inch pipe.
God I wish mandrel benders weren't 15k :/
Actually, I've seen (not first-hand) some good results with the HF pipe bender... If you fill the tube with sand. Here is a video on youtube with a guy showing how to do this. It is pretty informative. He keeps using the term pipe and tube interchangeably throughout the video, but he is referring to bending tube.
YouTube - Bending part 2
Can you imagine how much longer that would make a rollcage take?
You can also bend tube by heating it and bending it around a wooden die. Old motorcycle frames were built that way. I'll take the 30 seconds on a proper bender than you very much..
So let's say the HF bender is junk, what would you pros say is the cheapest bender that works. Let's not consider how hard or easy it works, just that it works.
Ebay![]()
i've been looking into build it yourself benders, and then buying the dies to suit it.
Benders are cheap. Not worth your time to build it yourself and probably won't save anything anyway.
Dies, now dies are expensive. That's where all your money goes when buying a bender and they are beyond the average DIYers ability to fabricate.
Someone here mentioned buying the bender and the one die set you are likely to need for your project. I'd second that rather than trying to cheap out and use a HF pipe bender, unless you want to bend pipe.
Not knowing any scientific or structural properties of steel tubing, or having ever worked with it,what would the purpose of sand inside the tubing be? that was mentioned on page 2. Would this help to keep the outside tube diameter at the bend? Also if you heated the tubing slightly would this not help it bend easier? or would this somehow affect the tubing?
Thanks
